CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
ignition/key problem
Old Jan 9, 2010 | 05:06 PM
sdt's Avatar
sdt
Question ignition/key problem
Got a problem and need a little if possible.
I put my key in my Bombardia 400 max 2004, and it wont come out. It woundn't is in the run position and i cannot turn it so the lights come on or cannot even turn it to the off position. Maybe water got in? Anyway I ended up forcing it so much to the off position that it just swivels around and still cannot get the key out. Big problem, little problem?
Advice needed
Thanks, Scott
Old Jan 10, 2010 | 07:52 AM
justme23005's Avatar
Just disconnect the battery, so it won't go dead, & buy a new switch.. you can probably find one on ebay.
Old Jan 10, 2010 | 08:17 AM
sdt's Avatar
sdt
Default thanks
thanks for the info, thats what i will do.
Old May 29, 2010 | 04:54 PM
brendo907's Avatar
i had a time that i didnt have a key so i just un plugged the 2 wires from the ignition and then put a wire that connected the 2 holes, worked fine
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
