Hi-lifter or Progressive Preload
Old Feb 25, 2001 | 09:25 PM
atvnut425's Avatar
I have a 2000xpedetion with 26" bearclaws. The front tires rub the fenders sometimes while riding
I installed the polaris rubber spacers but they don't seem to help. So which is better the lift or preload kit I also plow snow with my atv and whenI pick up the plow it really rubs! help?
2000 xpedetion
26"bearclaws
itp wheels
t1500superwinch
60" moose plow
Old Feb 27, 2001 | 02:42 PM
rangerchet's Avatar
Well, I also have a 2000 polaris xpedition 425 cc and I currently have 26 inch mudbugs. I had tire rubbing in the front also. I did buy from highlifter, the progressive lift springs/cams. My tire/fender rubbing is gone. So it worked.
However, now I have bought 27 inch mudbugs. I don't have them on yet. I am wondering if I may have tire/fender rubbing again.
I personally, don't want a lift kit, because then that is the weakest thing on your atv and it does cause extra wear and tear on some stuff. If I have
fender rubbing, I am not sure of my next move, but
it has to be a fix other then lift kit.
I believe your fender rubbing will disappear and the front is real stiff with those progressive lift setup, which should help you out. Since the cams are right on top of the springs there is no angle changes, so any extra wear, I think is minimual with progressive lift. I don't have a plow, but I know my machine and if I did have a plow on. The progressive lift stiffness would have
done the trick. rangerchet
speedbuff
13
Nov 11, 2020 10:16 AM
DrZew
Club News and Events
Aug 8, 2015 11:59 AM
Captjay
Jul 23, 2015 12:33 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
