Best way to drain fuel tank on 04' TRX250 Recon?
Old Jan 10, 2010 | 09:44 PM
ProSport's Avatar
Default Best way to drain fuel tank on 04' TRX250 Recon?
Sorry for the dumb question as you guys have probably answered this before but I couldn't find it in the search section.
I haven't had time to even look at it or dig out the manual but it won't start and I know the gas has been in it for several months w/o being ridden. Battery is new, it turns over fast but won't fire.
Old Jan 10, 2010 | 10:45 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Take off the plastic in the tank area, take the tank off and dump it out upside down. You will have to turn the valve off, and pull the hose off the valve first.
Old Jan 11, 2010 | 06:32 AM
zitaron's Avatar
Before you pull the tank -- try opening the drain screw on the carb a turn or two - that is the very bottom screw on the carb facing OUT to you. Let a flow of gas onto the ground, then try firing it up.
Old Jan 11, 2010 | 08:14 AM
Red Rider
But get that nasty old gas out of the tank first!
Old Jan 13, 2010 | 07:00 AM
ProSport's Avatar
Thanks guys, I emptied the fule tank and drained the carb, added new fuel and it fired up as soon as I hit the button!!
Old Jan 13, 2010 | 12:24 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
add Stabil to your fuel and it won't gum up the carb if you let it sit for a few months
SDR-II
Sep 29, 2015 01:06 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Shifts
Jul 3, 2015 07:59 AM
