honda big red 250 alternator issue
Old Jan 13, 2010 | 02:54 PM
chopper1982's Avatar
Default honda big red 250 alternator issue
Can any one tell me how to check the alternator and cdi. The bike starts and runs fine with the kickstart and battery, but doesn't charge. and the lights only work when the battery is in, and some time when there is no battery the nuetral light occasionally works?
Old Jan 13, 2010 | 05:52 PM
HondaMechanic's Avatar
Here is the alternator tests , you just test between the 3 yellow wires , then check each to ground .. Your reg/rec tests probably won't test right with this test without a Sanwa SP10D or SP15D meter ..
Old Mar 14, 2010 | 01:20 AM
drjoe171's Avatar
mine runs great with NO battery at all. I just put one in today and it reads 12 volts off, 14 at idle and a little less when slightly revved. I wonder if it's easy to check your regulator? if it runs, the cdi is OK, DONT question it! sometimes that battery will act AS a regulator tempering the charging circuit. so it runs without the battery?? that means you have enough alt output to run the engine. occasional neutrallight with NO nattery? sounds like it might be searching for a ground. clean them ALL up and it might work. free and easy test the regulator \free and easy voltmeters are 2.99 at harbor freight and prob walmart too lights only work with the battery in? They should work withOUT a battery within 10 feet of the machine. Maybe the battery IN just dplicates a ground that isn't completely happy. If I didnt love/NEED these things I'd get a few golf carts and sleep at night. keep me posted
skinnyr6
Aug 25, 2023 02:18 AM
Captjay
Jul 23, 2015 12:33 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
MNatv89
Jul 7, 2015 11:36 AM
