Magnum 330 Crankcase Wiring
Old Jan 16, 2010 | 04:39 PM
manum's Avatar
Default Magnum 330 Crankcase Wiring
OK-I have a 2005 Magnum 330-I have two wires hanging down from the fron. One is a three wire (red white black) that appears to go to the speedometer and low and behold the speedometer does not completely work. Only the tach.
In addition to these, there is a pair hanging down as well. It goes to the 4x4 switch I think. Looking over at the front gear box there is a hole in the right side. My guess is there is a switch that has fallen out.
Is this correct and can anyone give me a part number and maybe post a photo.
Thanks-I have gotten some good help here.
Old Jan 17, 2010 | 10:26 AM
manum's Avatar
I have gone over a few online manuals and have not seen what connection is required on the front housing for the switch or connector to the speedometer wires and the all wheel drive switch wires mentioned above.
Thanks again-FYI dropping the rpm's has helped my shifting dramatically. The response on the adjusting screw was minimal so it was difficult to tell if it was working. I think it was turned up at some point to compensate for the fuel issues it had.
Back to the speedometer and AWD-it appears both attach a common connector..
frostphase
Aug 19, 2015 07:11 PM
QuadCity
Aug 13, 2015 12:58 PM
DeFox500
Jul 26, 2015 06:32 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
