2007 sportsman 500 EFI crankcase seal
Old Jan 16, 2010 | 08:08 PM
mpolaris111's Avatar
Default 2007 sportsman 500 EFI crankcase seal
Does anyone know how to check for a leaking crankshaft seal. I think it may be sucking air by, but not sure how to check. Thanks in advance for any help you may be able to provide.
Old Jan 17, 2010 | 06:54 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a riskey way is to srapy starting fluid down behind the primary clutch(or take it off)onthe crank seal to see if the idle raises up when the bike running. if it does you have a leak. imo
Old Jan 17, 2010 | 07:39 AM
Does the mag side of the crankshaft ever bother or is it most generally the primary clutch side.
Old Jan 17, 2010 | 10:35 AM
The only problems I've had on the 4-stroke 500 seals is on the clutch side,usually distort or even pop completely out. OPT
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Coryco
Jul 6, 2015 07:30 PM
Sjrpp
Jul 5, 2015 09:04 PM
