changed ignition and now won't pull start???
Old Jan 17, 2010 | 12:45 PM
kram2724's Avatar
Default changed ignition and now won't pull start???
i bought a 2001 polaris trailblazer battery was bad but pull started easy. guy also lost the key so he drilled the ignition or somethin so somehow it would start. so i replaced the battery and ignition. so now i have power and lights come on and go to start and i just get a loud click by the battery i think maybe the relay?? well anyway i just figured i'd keep pull starting it so i go to start and nothing!!!??? i don't get why now it won't even pull start?? any help would be great thanks....
Old Jan 17, 2010 | 04:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like maybe the starter is bad. w/ key on try jumping the 2 big wires on the relay(solenoid) by the battery. if it still clicks then it's the starter is the issue. as far as the ignition, it may be it is either hooked wrong or maybe some how he has grounded it out. also check the kill switch to make sure it's on and working.
Old Jan 17, 2010 | 05:47 PM
kram2724's Avatar
i don't know what i did but i just pulled and pulled and pulled and finally it started up. so now i have that issue fixed. i'm hopin that the relay is just bad instead of the whole starter. so how exactly do i jump the two wires together? and what will that do? sry i'm not the best mechanic i kinda just teach myself as i go. haha.
thanks
Old Jan 17, 2010 | 06:29 PM
ctdnwakulla's Avatar
The best and safest way is to use a starter button, they can be picked up cheap at any parts house chain store. The other alternative is a screwdriver if you can short the posts, but be carefull !!!!
Old Jan 18, 2010 | 09:56 AM
kram2724's Avatar
ok i'll look into one of those. would the screwdriver way shock the **** outta me or somethin?? and i ordered off ebay another relay off a trailboss anyway but it looks like its the same one....hopefully it will work???
Old Jan 18, 2010 | 12:13 PM
No, not a shock you can get a burn if not carefull, due to arcing. good luck
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
bigg_fatt_monn
Jun 16, 2000 09:41 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
