over heating with sportman 400
Old Jan 23, 2010 | 05:46 PM
lenb57's Avatar
Default over heating with sportman 400
i have a problem my 400 overheating. Yes the rad is very clean . one thing i have notice is that cooling fan suck air through the rad rather than blowing it out the front. This i don't understand is this normal .
Old Jan 23, 2010 | 06:50 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Yes that is normal............When you say your RAD is clean ...How do you know?
Did you look at the back fins where the fan housing is?
They get build-up there.............Caper............
Old Jan 23, 2010 | 08:11 PM
lenb57's Avatar
I clean it myself and them also had the deal clean the rad
Old Jan 24, 2010 | 03:46 PM
mine1's Avatar
I have a 05 700 that gave me same issue for a while. I cleaned rad. and was 100% sure was clean. I thought the system was full of anti-freeze and still had problem. I finally tried what the manual says, " Burp the system to remove any air from system". Crank the atv up with rad cap off, let run till the thermostat opens and then gently squeeze the top hose slowly at the first bend, try this several times and hopefully will get the air out of system. This worked great for me and I was sure this was not my problem but found out it was. Good luck!
Old Jan 24, 2010 | 06:22 PM
lenb57's Avatar
thanks i will try that
Old Jan 25, 2010 | 08:33 AM
4getful2's Avatar
2 or 4 stroke?? any bubbles in the coolant when running??
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
poutlaw525
Sep 9, 2015 03:19 AM
