Polaris sportsman sway bar
Old Jan 27, 2010 | 08:54 PM
polaris man with issues's Avatar
Default Polaris sportsman sway bar
I have a 05 polaris sportsman 500 ho. Im a big guy. Does the sway bar do anything with weight distribution? Also i do some rock and trail and mud rideing. If i disconnect the sway bar what will it do to the ride or the handling of the atv? Should i leave it on? thanks Polaris Man with Issues
Old Jan 27, 2010 | 09:58 PM
lovmudd's Avatar
Sway bars prevent body roll in turns at higher speeds. The higher the speed the more body roll thus the more need for a bigger or stiffer sway bar.
Given your weight I would think it a benifit for ride comfort, in trail riding.
I think people remove it for two reasons, 1 for tire clearence, 2 for better tire traction in very rough situations like rock climbing at slow speeds where body roll is of no concequence.
Old Jan 27, 2010 | 10:07 PM
switzomatic's Avatar
Might want to look at going with stiffer springs. Here's a link to the quick-disconnect swaybar mod. http://www.atvnation.com/modules/AMS...hp?storyid=168
Old Jan 27, 2010 | 11:07 PM
reno82's Avatar
Quick disconnects is a standard feature on Jeeps set up for rock crawling, but i never ran mine disconnected unless it was slow crawling and i needed all four on the ground. Sounds to me your need is for stiffer springs. Disconnecting the sway bars on a quad, like my jeep, may be fine for slow rock crawling, but I wouldn't want to be flying down the trails disconnected, you will end up with a lot of body lean and possible roll over.
Old Jan 28, 2010 | 05:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the heavier the load being carried on the bike(IE the rider) would have more body roll w/ the bar disconnected and to me make it more dangous. imo
Old Jan 28, 2010 | 10:49 AM
Ditto Sten. Definitely do not want it disconnected unless you're crawling in some nasty stuff! Highly suggest the hd springs unless you have the $ to get a set of elka shocks.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
