tight clutch pack?
This is another question about the same Tao Tao 125D that I recently bought for my son. When the unit is put in either forward or reverse, the unit will move on its on. I cant adjust the idle low enough so that it will stand still. Is this something that will correct itself with time or should the clutch pack be adjusted, assuming this is even possible.
Thanks
Bill
Thanks
Bill
Get 8-10 hours on it & this will go away, maybe even less than that & you will see a improvement, its not slipping the way it should at idle & usually this will fix its self because the plates will slip for you & not move the machine. Be sure to change the shipping oil out also, this will help. I recommend Castrol 10W40, don't use synthetic as this will actually cause your clutch to slip to much after time & you will have to replace it.
Lou Domenech
Sep 11, 2015 06:35 PM
cdstang
Aug 31, 2015 07:52 AM
