Razor throttle cable freezing up
Old Jan 29, 2010 | 09:43 PM
Tigerracer's Avatar
Unhappy Razor throttle cable freezing up
Two friends of mine have had their throttle cable freeze up today. Temps around 15 degrees. Any one else?? Any solutions??? Both razors are pretty new.
Old Jan 30, 2010 | 06:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
don't use wd-40 or any other water base lube on the cable. you need a cable lubicant and a device to force it down the cable to help lube it and unfreeze it.
Old Jan 30, 2010 | 07:21 AM
Make sure the throttle body butterfly is not dirt contaminated, clean with carb cleaner if needed,this can cause sticking problems.Also check that you have slight slack at pedal,adjust cable if needed. We've had a few sticking because of sand/dirt contamination because filters were not properly maintained. Also check that there are no sharp bends from cable routing to throttle body. OPT
Old Jan 30, 2010 | 08:32 AM
HeftyLefty's Avatar
Squirt a syringe of antifreeze down the cable. That's what the snowmobile folks do.
Old Jan 30, 2010 | 08:40 AM
gaspumpcity's Avatar
Your right on HEFTY
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
Brandon400
Sep 7, 2015 12:20 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
