Polaris 2 stroke 90cc
Old Jan 30, 2010 | 10:08 AM
6adan's Avatar
Default Polaris 2 stroke 90cc
I am working in this for my neice. I need the ring end gap and the cylinder to piston clerence and the stock bore size. This would be let me know if I need to bore it and how much.
Thanks Dannie
Old Jan 30, 2010 | 10:25 AM
They are set up pretty tight from the factory. If the bottom of piston to bottom of cylinder skirt is over .0025 I would bore to next oversize. Just insert piston into cylinder from the bottom and pull piston against one side and use a feeler gage,easiest way to check. New bore should be between .001 to .0015 final clearance after honing. Ring end gap minimum .008
Old Jan 30, 2010 | 07:32 PM
6adan's Avatar
Thank you. With your measurments I will be able to install new rings and everything should be fine.
Thanks again Dannie
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
kelleycully
Sep 15, 2016 02:57 AM
Ramman1
Jun 16, 2016 09:07 PM
SDR-II
Sep 29, 2015 01:06 AM
Gnuters
Jul 19, 2015 10:03 AM
