Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2008 ltz 400 clutch problem
Old Feb 3, 2010 | 06:22 PM
fiziks's Avatar
Default 2008 ltz 400 clutch problem
So when i start my quad in a gear with the clutch pulled in it starts to take off on me, so i thought i needed to get it adjusted so i went to the dealer and got it adjusted for free and then i went and took it out for a weekend and it still does the same thing and the mechanic said it was the clutch so i pulled the cover to the clutch basket and did not take it any further but the clutch disks look ok no shavings in the cover... can the clutch disks still be bad?? any ideas?
Old Feb 3, 2010 | 11:04 PM
poolsean's Avatar
Not sure how they would have adjusted your clutch and released it back to you with the same problem. I wouldn't take it back there again, even if it was free.
Did they adjust your clutch cable? If your clutch plates were worn, it would slip, not continue to move when you have your clutch pulled in...so IMO, it's not your clutch plates.
If your clutch lever is not adjusted properly or the cable is stretched, it wouldn't allow the clutch to fully disengage...at least that's logical thinking.
Hopefully someone more mechanically wiser than I will come along.
Old Feb 4, 2010 | 07:18 AM
fiziks's Avatar
well right after i picked it up it worked fine for like 20 min then it started to do it again so i dont know whats goin on but thanks bud
bzdok1234
30
Feb 23, 2016 01:55 PM
coolguy420
Jul 10, 2015 01:17 AM
traumajunkie
Jul 5, 2015 03:03 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
