1998 sportsman 500 charging problems
Old Feb 4, 2010 | 09:21 AM
weights133's Avatar
Default 1998 sportsman 500 charging problems
I have an 1998 Sportsman 500. It seems that im replacing battery about every 3 months or either having to charge the ones that are in it. Does anyone know what the problem could be? Ive heard the rectifier could be bad, the modulator, so on. Is there any way i could find out what the issue is or can you guys offer any help? Thanks alot!
Old Feb 4, 2010 | 10:59 AM
TLC's Avatar
TLC
Get a voltmeter on the battery terminals.
With the ATV shut off should read 12v at the battery,and with motor running at 4000 rpm it should read 13V - 14.6V.
If your ok and still have troubles I would change the Voltage Rectifier/Regulator.
Old Feb 4, 2010 | 01:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
try unhooking the recifier and checking the connection for corrsion. as mentioned above w/ a tester you should be able to check voltage.
Old Feb 5, 2010 | 07:54 AM
Kerbbirds's Avatar
Regulator in front of radiator is bad. Usually the problem, do some testing with a meter to make sure its not charging first.
ripperray
Oct 10, 2023 02:42 AM
nature violator
Jul 3, 2015 08:40 PM
bikedad3
Jun 29, 2015 08:58 AM
clsharky
Jun 8, 2015 11:38 AM
Joe Paul
May 27, 2015 09:04 AM
