popo with trans / rear diff chatter?
Today was the first day I took my new (158 miles on the atv) 2006 Sportsman 800 out on the trails. This is the first time I've really ever ridden a polaris big bore atv-
Does anyone else have a chatter in the rear shaft when going down hills using only the engine to slow down in 2 x 4 mode? Or even just on flat trails over roots & rocks while in AWD- sounds like there's a lot of play in the drive shaft or diff. Everything looks normal.
Feels like the damn thing is going to fall out it chatters so bad!
actually- it dosn't seem to do it when I'm on the throttle, but if I blip the throttle it will- like you said "on / off"
"BeerGut" I have also noticed that if you go down a hill with or without the brakes and you go over a bump it clunks. Also happens when you go over any other kind of hump or bump. My brothers arctic cat also does it anyone know what it is??
does your rear foot brake do anything at all? Mine dosent
Only brake is the left lever, which operates all 3 disks (2 front, 1 rear)
if the noise your hearing is say when you first get onthe throttle or off the throttle, and like mentioned going the hill w/ no throttle at slower speeds, then your going to find that it is normal form what i mentioned above. the big bore(7 and 800's) are known for doing this becuse of the extra sloopy drive line. it shouldn't be making any noise in normal running or at normal speeds.
~Polaris Man With Issues
I have a slight chatter from the rear. It changes frequency depending on how fast you're going. I don't think it is the clutch though. On the rear brake pedal, mine does not work. It's seized in the "in" position. I talked to the guys at the dealership and they said it won't effect the brakes other than not having the pedal. I did lift up the rear in neutral and the wheels spin without a problem. And the hand brake works fine, so for now I'm leaving it alone.
