2006 sPORTSMAN 500 EFI PROBLEM
Old Feb 7, 2010 | 05:22 PM
DELUX500EFI's Avatar
BUY AMERICAN!
Default 2006 sPORTSMAN 500 EFI PROBLEM
There was an older post about Sportsman 500 EFI not liking water..We have a 2006 Sportsman 500 EFI that runs fine until it hits a small amount of water(splashing up under atv) and it starts missing and back firing..Today riding in the snow the same problem occured when riding in melting snow.Let the atv set for a short period and it runs fine..I am thinking the tires are throwing water on something that causes the problem..OPT or anyone have any suggestions...
Old Feb 7, 2010 | 06:14 PM
JCDEYO25's Avatar
I'm trying to remember but I think it's a coil issue...
John
chuck_raduenz's Avatar
start checking wire plugs, and or take every wire plug and fill it dieletic grease.
Old Feb 7, 2010 | 07:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed it sounds like a bad plug wire.
Old Feb 19, 2010 | 03:37 PM
BUY AMERICAN!
Smile
After completely stripping the plastic (body panels) twice we found the problem..There are two wires running from the crankshaft position sensor to the main wiring harness on the left side of atv.Where the wires crossed the hot wire (red wire) that goes to the starter both wires had rubbed through.(sensor wires and starter hot wire)When water came in contact this was shorting the atv out.without the moisture the atv ran fine..You folks with 500 Efi's may want to check yours out..
Old Feb 19, 2010 | 07:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
good info to have and glad you got yours straighten out.
Old Feb 19, 2010 | 07:56 PM
JCDEYO25's Avatar
Good info for sure...I think with all the wire rubbing problems these machines have, Polaris should run more wires in looms for protection...JMO...
John
Ltz250goon
Sport Quads
Dec 3, 2015 07:51 PM
toonces
Jun 30, 2015 11:19 AM
BillinIll
Jun 25, 2015 02:44 AM
BillinIll
Jun 19, 2015 01:39 PM
Joe Paul
May 27, 2015 09:04 AM
