Stuck left front sportsman driveshaft
Old Feb 15, 2010 | 01:05 PM
sportsman70004's Avatar
Default Stuck left front sportsman driveshaft
So the front hillard finally went out. Got all the parts (john deere) to replace it. So I gutted the front end and the right driveshaft came out very easily with a little spray and some tugging....the roll pin for the front prop came out with no issues but I simply can not get the left driveshaft out. I started this yesterday and spent 4 hours yesterday spraying, beating and prying and another 3 hours today. I have flattened the yoke to the point I doubt I will ever be able to use it because I will not be able to change the U-joint. Does anyone have any ideas?....just got done trying some heat on it but still no budge. This is on a 04 Sportsman..
Old Feb 15, 2010 | 01:47 PM
On ones likes yours that seems like its almost welded on from sand,dirt,grit,etc, I've found that a air hammer with a DULL flat bit usually helps to break the driveshaft loose from the gearcase shaft without damage to the yoke assembly. OPT
Old Feb 15, 2010 | 01:51 PM
of course the one tool that i do not have is a stinkin air hammer. thanks OPT....as always
Old Feb 15, 2010 | 02:05 PM
MECHANIKE's Avatar
i used a pipe wrench tight up against the yolk and hit it hard with a 5lb sledge..............
Old Feb 16, 2010 | 07:23 AM
Kerbbirds's Avatar
I use a slide hammer with a piece of chain looped around the yoke.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
WilliamBos
Sep 30, 2015 08:08 AM
wannabe32
Jul 7, 2015 11:30 AM
Fullblast
May 26, 2015 12:38 AM
