94 Polaris Sportsman 400 won't start?
Old Feb 16, 2010 | 01:22 PM
mekovich's Avatar
Question 94 Polaris Sportsman 400 won't start?
I have a Polaris Sportsman 400 2 cycle. The problem started when plowing snow. At first It would hesitate at 3/4 throttle then started to stall and finally wouldn't start. I Checked fuel tank and was full of water. Drained tank and refilled with clean fuel with a little of HEET to try and get rid of water in carb without taking it off. It started up Ok but still would not take full throttle. Then stalled again. Still can't get started. Have drained tank and replaced filter (No water) Completely dissambled and cleaned carb. (No dirt or water to be found) It will not fire. (Also changed plug) I did notice that when I remove the carb I don't see any signs of fuel? Help!!
Old Feb 16, 2010 | 05:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did the water freeze in the line or fuel pump?
Old Feb 16, 2010 | 07:10 PM
mekovich's Avatar
Default Water Freeze
No ATV was in heated garage
Old Feb 16, 2010 | 07:24 PM
4getful2's Avatar
is a steady stream of fuel coming out of the fuel line when you unhook it from the carb.??
you didn't by chance have a kink in the line someplace?
Old Feb 16, 2010 | 08:46 PM
mekovich's Avatar
Yes got fuel to carb. Bowl is full when I drain. Steady stream when I open up fuel valve
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
Schneider
Jun 4, 2015 11:37 AM
May 27, 2015 11:15 AM
