Coolent leak
Old Feb 27, 2001 | 02:18 PM
Dazed's Avatar
Ok this is on a 2000 sp 500 with 500 miles on it The owner (Not me) Is not to mechanicly inclined. His wheeler is leeking coolent from the lowerr end near the water pump Would that be the mechanical seal or coulsd it be the cover gasket. Can this be fixed with out the use of the dealer or is it a dealer fix? Help He is selling it this week and needs to get it fixed.
Old Feb 27, 2001 | 08:35 PM
NewDSLover's Avatar
Bars leak works great on small leaks. Most MFG's put this in during production. But if it's within it's 6mon. warry., then take it in. But if it's not, then put in a half a bottle of BarsLeak and run it for awhile and check again.
Old Feb 27, 2001 | 08:48 PM
ChopperBill's Avatar
Believe it or not we have never had to replace the seal, but I know you can replace it pretty easy but may require a special puller for the old seal. We have a puller but never had the oppertunity to use it.
Old Feb 28, 2001 | 02:10 AM
Dazed's Avatar
I went and looked at the bike today and it is definatly wet there and on the frame to it is antifreeze so what else could it be? What happens when you take the water pump cover off will it loose all the coolent or will the mechanical seal keep that from happining?
Old Feb 28, 2001 | 10:11 AM
Farmr123's Avatar
If you look (really really close) you should see a weep hole in the casting. This is essentially a vent between the oil seal and water seal. If the coolant is leaking out of that, the seal is bad. If not, it may just be the gasket.
Hope this helps.
I suppose now someone is gonna tell me they don't have the vent hole anymore, but the older ones have it for sure. It may be hard to find, but should be there. I emphasize should.
Old Mar 1, 2001 | 01:53 AM
Dazed's Avatar
Well the problem is solved My buddy Brad brought it to the dealer today To get fixed So atleast there is his peace of mind.
Dazed's Avatar
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
