87 250x ignition troubleshooting
Old Feb 23, 2010 | 09:46 AM
rapple's Avatar
Default 87 250x ignition troubleshooting
Help... I just reinstalled my rebuilt motor and I've got no spark.
Unfortunately, my shop manual is for a 300ex. Lacking a battery, the 250x electrical system is different enough that it's not much help... plus trying to measure voltage for the 1/2 second that the motor is turning while kicking it is problematic at best.
Does anyone have the resistance values for the stator, CDI, coil etc handy?
TIA
Old Feb 23, 2010 | 10:41 AM
budedm's Avatar
Send me a PM with your email and I'll email you 2 pdf files for testing the ignition of the 87 250X.
Old Feb 25, 2010 | 08:17 AM
KNOWSALOT's Avatar
The Facility
Ruling out the possiblity of a bad sparkplug (I take it you already tried that) there shouldnt be a "problem" with your electrical system.
If it had spark prior to removing the engine you simply have to retrace your steps and see where you left something unplugged or let something get corroded while it was sitting up and clean it up.
You don't have a component failure.
Old Feb 25, 2010 | 07:00 PM
HondaMechanic's Avatar
Have you done all the tests ...
1987-88 250x components
Ignition tests
Old Feb 27, 2010 | 04:20 PM
rapple's Avatar
OK, stupid question. Does the reverse switch need to be connected for the engine to start? I've got a broken wire on the reverse switch. Since it's cold in my barn, I figured I'd just tape it up until spring and fix it later.
It has now occurred to me that perhaps the CDI needs to see a signal from that.
If not, I'll start running through all of the component tests when things warm up a little...
Old Feb 28, 2010 | 12:21 PM
rapple's Avatar
Well, I guess the reverse and/or neutral switch does need to be connected (at least the way this beast is wired). I'd left them unhooked because the wiring is in bad shape and I figured I'd deal with it when the weather was a little nicer.
I hooked them up and the engine fired on the 3rd kick.
Now I'm counting the days until spring!
Old Jun 10, 2021 | 05:27 PM
Travis87trx250's Avatar
could I possible get the files for testing ignition I have same quad and lost spark after cleaning carb very frustrating and been working on it for a week with bo
luck
Old Jul 3, 2021 | 05:16 PM
GoFast80's Avatar
Default LT230 ignition coil
On my new coil that I ordered. It isnt marked + or -. It's color coated light green and black. Which would be the positive prong?
Old Jul 4, 2021 | 02:14 AM
Looks like you are asking about a Suzuki part in the Honda section of the Forum. All I can tell you is Honda use green for earth and black/yellow (usually) for the feed from the CDI to coil, so mark the coil green and black. Suzuki, however use black/white for earth and, on their modern stuff anyway, different sized spade connectors so you can only fit the Suzuki coil the right way round.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
