Carb problem!!
Old Feb 27, 2010 | 06:01 PM
dupont's Avatar
Default Carb problem!!
I am trying to fix my warrior and when I put the carb on, gas was pooring out all over?
Old Feb 27, 2010 | 07:39 PM
mikel1's Avatar
Gas pouring all over. I take it the carb is flooding, check the carb. float and float valve assembly. It's probably sticking, try cleaning it and see if that helps you out.
Old Feb 27, 2010 | 08:18 PM
91Warrior357's Avatar
that usually happends when the float is stuck, then it pours out the overflow tube, take the bowl off and make sure the pin that holds the bowl on is on correctly and isnt binding up against the walls of the bowl, if you want take something and tap the side of the bowl and see if it stops but dont do it to hard.
Old Mar 13, 2010 | 01:16 PM
dupont's Avatar
The float is ok, I think the accelerator is stuck
Old Mar 13, 2010 | 05:35 PM
the spring for the accelerator pump plungers are so crappy, get a spring from a clicking pen and use it, works so much better and wont bind, stick, and intermittently work.
Old Mar 14, 2010 | 10:41 PM
dupont's Avatar
I got a rebuild kit, rebuilt the carb, and I put it on today. It runs great.
Old Jun 7, 2010 | 03:32 AM
ttaylor137's Avatar
What kit did you purchase and where from?
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
