350L oil pump ?
Old Feb 28, 2010 | 09:00 AM
hoytultratec's Avatar
Default 350L oil pump ?
trying to help someone out, the oil pump cable broke at the pump, its a new rebuild and he wants to premix 2 tanks for break in and the new cable wont be here till mid week, without a block off plate will it hurt anything if he runs it with the premix fuel?
Old Feb 28, 2010 | 09:12 AM
I,m pretty sure no is the answer...but still wanting the kid to be safe.
Old Feb 28, 2010 | 11:54 AM
94harley's Avatar
He should be fine.
Old Feb 28, 2010 | 12:02 PM
I read a few posts basically saying that if there is not enough oil in the pump at higher rpm's its possible to seize the pump? the reason why they remove the pump and block it off? so basically with a broke cable the pump is closed and wouldnt put oil in the pump.
thanks for any advice.
Old Feb 28, 2010 | 12:06 PM
94harley's Avatar
The pump itself gets oil by gravity feed and would have an endless supply of oil as long as the oil tank is full. Since the cable is broken it just won't put out the correct amount at high rpm to the motor as the pump arm will not come off of it's "idle" position. The guys blocking off there oil pumps are wanting to pre-mix it only and wouldn't have that supply from the tank and the pumps would run dry, ruining them, or siezing them.
He should be fine as long as there is oil in the oil tank.
Old Feb 28, 2010 | 12:13 PM
makes sense.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
