Brake pad question
Old Mar 5, 2010 | 07:37 PM
dontgetbehindme's Avatar
Default Brake pad question
I was wandering if anyone has found pads that last longer than Polaris brands, I have seen those advertised pads that say slintered, is this any better or cheaper? Any imput is welcomed.
Old Mar 5, 2010 | 08:50 PM
HeftyLefty's Avatar
Sintered pads dissipate heat better due to both a harder compound, and grooves in the pad, to remove mud, water, and heat .
The two most common causes of brake pad wear are hard use and dirt. If you mud alot, clean your pads with brake cleaner after every ride.
EBC makes good pads, or you can make your own with clutch lining material from McMaster-Carr , and JB Weld or similar adhesive.
Old Mar 5, 2010 | 08:55 PM
DODGE57HEMI's Avatar
Mopar Man!
EBC Extreme Pro pads.
Old Mar 6, 2010 | 05:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yep ebc are very good replacement pads and not as expensive.
Old Mar 6, 2010 | 07:33 AM
400x's Avatar
Scared to death of girls!
Originally Posted by dodge57hemi
ebc extreme pro pads.
+1
Old Mar 6, 2010 | 11:37 AM
Ok thanks, I didnt want to buy some off brand that didnt hold up, I bought some off brand years ago and they wore out in 2 weeks, beem weiry of getting anything other than Polaris
Old Mar 6, 2010 | 03:58 PM
DELUX500EFI's Avatar
BUY AMERICAN!
I have tried all the name brand pads and the Polaris pads seem to hold up as well as any.The only thing is they are more expensive.We have three 800's and put three different brands on each and then checked them after about 300 miles..The Polaris and EBC wore about the same..the ones from e-bay no name were complety worn out..So I guess you get what you pay for..(the e-bay no name brand were very cheap and it showed)
Old Mar 7, 2010 | 01:54 AM
chuck_raduenz's Avatar
wow. i had a 2000 with 7k on it. never touched the pads. brake happy are we......
Old Mar 7, 2010 | 09:58 AM
Ride hard and put her up wet, When you ride in the hills of Tn. brakes are your friend
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Oct 16, 2019 12:11 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
