Warn 2500 winch quit
Old Mar 6, 2010 | 11:54 AM
ftwflh's Avatar
Default Warn 2500 winch quit
The switch button seems broken and just get a click at the relay.Any help on this and what parts will interchange.Thanks
Old Mar 6, 2010 | 12:11 PM
DODGE57HEMI's Avatar
Mopar Man!
there are tons of threads pertaining to this topic as it is your contact and depending on the year they are under recall.
Warn Industries Inc. Recalls Eight-Post ATV Winch Kits for Overheating
Old Mar 6, 2010 | 03:15 PM
DCT's Avatar
DCT
Banned
ftwtlh,
Sounds like the contactor... but don't assume it.
Anyhow, is it a 4 post contactor, or an 8 post? If it's a 4 post, any of the new contactors should work. I would suggest another Warn or a new Viper contactor. If it's the rocker switch, I would stick with a Warn. They should all be the same... one hot wire, and two signal wires going to the bottom of contactor.
Check, clean and put some dialectic grease on ALL connections (including to the battery) before you start buying stuff. It could be a loose/corroded connection anywhere. The winch (and contactor) need a pretty good supply of juice to function properly.
Old Mar 6, 2010 | 04:05 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
most likely the contacter is the issue.
Old Mar 6, 2010 | 06:21 PM
ftwflh's Avatar
thanks guys when I gt time I will chexck it out.Took it out today for the first time since a head gasket job and the bike did great
Old Mar 6, 2010 | 07:47 PM
chuck_raduenz's Avatar
test the switch. find out where the switch wires connect to the contractor via 2 bullet type plugs. unplug the wires. take a test light and check the plugs while pushing the up and down buttons. if the test light lights up on both wires. ill bet its the contractor. but if its clicking its mostlikly the contractor. just cuz its clicking dont mean its working.
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Johnny Mac
Aug 15, 2019 03:13 PM
wrencher82
Sep 30, 2015 04:27 AM
cboler9
Sep 24, 2015 08:35 PM
