xp transmission oil
Old Mar 6, 2010 | 06:07 PM
canaan canam's Avatar
Default xp transmission oil
i just bought an 09 550 xp eps this is a replacement for a previous polaris my dealer told me to use xp transmission oil not agl said use new stuff i have 4 gal of amsoil chaincase anybody heard this or is he just trying to get deeper in my pockets hes a good guy but they are in it for the money thank you keep the shiney side up
Old Mar 6, 2010 | 06:26 PM
lovmudd's Avatar
I would stick with the XP transmission oil on this one.
Good luck trying to get the inspection and drain plugs loose. I have yet to get them out and have tried twice, and given up, because I am affraid of striping the 8mm hex bolt. Talked to the dealer about it, and he laughed and said he uses a long breaker bar and to go ahead and give er.
I'm still leary about forcing it, as it looks to be an aluminum plug and it is really sealed in there.
Anyone else run into this on a XP?
Old Mar 6, 2010 | 06:33 PM
gaspumpcity's Avatar
What I do get small brass punch flat face 1/2 and smack it with a small 1-2 # sled hammer. The aluminum plug is boss oring the plug will come right out with the allen wrench.I replace the plug too there cheap
Old Mar 6, 2010 | 07:33 PM
lovmudd's Avatar
How are you hitting it? Are you hitting it from the side, catching an edge, and trying to rotate it ccw or just hitting it straight on like you would with a hand impact wrench?
Old Mar 6, 2010 | 08:05 PM
FunRide's Avatar
Yep. Get the right sized hex wrench and give it to it. I had to use a vice grip on my hex to get enough torque. Now that I've done it once and broken the factory over-torque, it's fine.
Old Mar 7, 2010 | 10:09 AM
Smack the plug with a flat edge punch on the face of the plug!This plug is soft and will come right out.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
