04 sportsman 600
Most likely your stator/pick-up. Open up your recoil and take a look. Start the machine up first and use a multi-meter as see if your voltage is above 13vdc. If it is, shut the machine off and take another reading. If your battery is below 12vdc, I'd replace it as well. It may be bad. If your at 13vdc while running, your stator/pick-up are most likely ok.
try checking the recifier as wel to see if it is all corrode or maybe unplugged. it controls the amount of voltage you get. if dirty or corroded, clean and then put some dielectric grease on the connections. it should be located up under the front by the top of the rad. or near the pod under the plastic panel. imo
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
