1997 Yamaha Timberwolf running problem
Old Mar 16, 2010 | 03:33 PM
heavyhammer7's Avatar
Default 1997 Yamaha Timberwolf running problem
The atv will start run and idle fine until every once in a while it sort of "burps" and sometimes after the burp will stay running other times it will stall out. The burp comes from the airbox and seems to push air against the cover of the airbox. Ive checked the carb and its clean and i checked the boots on the carb and they seem ok, suggestions anyone? Summer is approaching fast and I want to ride without this stalling on me in the woods all the time
Old Mar 26, 2010 | 01:01 PM
juice72579's Avatar
mack sure screws are tight on air box and mack sure its sealed good
Old Mar 26, 2010 | 02:56 PM
I think I fixed it, I adjusted the screw on bottom of carb that I think is the pilot screw or something and it helped the sucking noise go away. It still happens a little but as long as its pretty warmed up its fine, thanks to all for suggestions =)
wildbill59
Jun 9, 2015 02:28 AM
wildbill59
May 28, 2015 12:05 PM
lakota10567
May 5, 2000 01:52 AM
cj7
Nov 18, 1999 12:10 AM
Rob
Aug 31, 1999 11:37 AM
