Grizzly 660 shifting problems
Old Mar 18, 2010 | 03:52 AM
winner1k's Avatar
Default Grizzly 660 shifting problems
Can anyone help with this? I have a 2004 Yamaha Grizzly 660 with the auto transmission. When I shift out of neutral to hi or reverse, sometimes the ATV bucks. It doesn't happen all the time and it doesn't affect anything else. Rides nice and pulls strong. I'm real new to these vehicles and just starting to learn.
Any help would be much appreciated- Thanks
Old Mar 18, 2010 | 01:53 PM
CraZySteve's Avatar
Red face
The shift linkage needs to be adjusted
Follow Hefty-Lefty's advice:
http://forums.atvconnection.com/yama...g-problem.html
Old Mar 18, 2010 | 02:39 PM
BVRDUK's Avatar
Food for thought! I ride an 05 Griz 660 and mine will do as you said from time to time. I have found that problem only when engine is reved too high. Let the engine idel down before you shift and i think you will find the problem gone.
Old Mar 18, 2010 | 03:08 PM
CraZySteve's Avatar
Ah yea.. Doh! I should have completely READ the First Post!
he's right - if it is rev'd to high it will clunk / buck into gear - I've experienced that on my 450
Old Apr 1, 2010 | 08:01 AM
ALF03's Avatar
Agreed. The 660's run a wet clutch, nothing should be trying to turn in there unless the idle is set at too high of a speed. Adjust idle.
Old Apr 1, 2010 | 09:44 AM
TLC's Avatar
TLC
That goes for all CVT drives of any make, You must be at idle before you try to shift.
RedRancher
Oct 15, 2020 01:45 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
toonces
Jul 11, 2015 12:01 PM
sara durrant
Jul 6, 2015 05:32 PM
