Help with stator testing. Will it run?
Old Mar 18, 2010 | 06:40 AM
tyhoppy's Avatar
Default Help with stator testing. Will it run?
I have weak spark on my machine. I replaced the CDI box to no avail. I checked the ohms of the stator and I'm leaning towards the pickup coil. Tell me what you think.
The source coil spec should be between 270 - 330 ohms. I got 250. I'm guessing that 250 would still run because it is less resistance than spec. But I'm not positive.
I do know that my pickup coil is bad because I get 350 ohms and spec is 171 - 209.
So, will the ATV run with the source coil at 250 if I replace just the pickup coil? Or should I replace the entire stator?
Thanks.
Old Mar 18, 2010 | 08:38 PM
91Warrior357's Avatar
im guessing this is a warrior, if its below spec then there done, i would get the whole stator, from RM or Rickys.
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
