shifting problem!!dvx400
Old Apr 1, 2010 | 07:06 PM
mydvx400's Avatar
Default shifting problem!!dvx400
hi new to this site, i have a 2003 dvx400 it seems to be shifting into every gear but still seems to be stuck in first and even in first it has no umph like sometimes it will not move at all revs like it wants to go but wont move....any ideas...clutch release crankshaft?...
Old Apr 4, 2010 | 09:23 PM
mydvx400's Avatar
Default any answers?
can some one give me advise? just looked at the clutches today and they look ok still have about an 1/8 of an inch left on the friction plates but still will not shift out of first!
Old Apr 5, 2010 | 10:13 AM
Speeddrive1's Avatar
could be the springs in the clutch. Need to take the springs out and measure them to make sure that they are not collapsed. Do you use oil for wet cluches in it? If you are using regular automotive oil it could cause the clutch to slip.
Old Apr 5, 2010 | 02:37 PM
mydvx400's Avatar
not sure what the specs are supposed to be for the springs but i will find out.
i do use a clutch oil and oil for the motor and starter. first gear seems to drive ok still not to the full potential of where it should be but what gets me is that it will shift through all the gears but is still stuck in first. and i say this because i can manually shift the gears and if i go to fifth i have to shift back down to get it in neutral. i have no clue what the deal is but if any one can help it would be great!
Old Apr 5, 2010 | 03:34 PM
are you sure the clutch isn't slipping?
Old Apr 5, 2010 | 04:14 PM
mydvx400's Avatar
no not slipping the friction plates look good stll enough left to ensure it will catch, but will not come out of first. do you know if i would have to split the case for the clutch fork or can i get to it from the cluches side by taking out the basket?
Old Apr 5, 2010 | 07:43 PM
check your pm mydvx400, might get more help there.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
