just bought 97 honda 300 4x4,possible mech problems?
Old Feb 28, 2001 | 11:20 PM
kpwhite's Avatar
first time user,trying to avoid any common mech problems on the trail.
Any recommendations? (mileage approx 1600 km)
Thank's for any help!
Old Mar 1, 2001 | 10:55 AM
Rangercd's Avatar
I have a 97 300 and I can't tell you about any problems. Change the oil and add gas, ride it. Mine gets used for pulling trees, heavy trailers and getting around camp. I have a 1500 superwinch on it that I have had to use a couple of times while using it in the creek to pull debris out of the creek. Have fun on it.
Old Mar 1, 2001 | 12:28 PM
realoldguy's Avatar
have had 3 different 300 4x4 a 96,97,and 99. like the man said gas and oil. They are great and bullet proof. The only problem I have is they ride like a log wagon. But other than that they are great good luck.
realoldguy
Old Mar 1, 2001 | 12:36 PM
makwheeler1's Avatar
I had a '92 300FW and had only one recurring problem......FRONT BEARINGS......they suck water.
It's a couple hour job. To see if your bearings are good, jack up the front end and grab the front wheel at the top and bottom and try to wobble it. If it wobbles, the bearings may be bad (or the CV shaft nut may not be torqued correctly). If it doesn't wobble the bearings are probably good. This is somewhat of a soft spot with Hondas as the bearings are not truely sealed and there is no way to relubricate them without disassembly.
p.s. I would remove the air filter (on any machine) and clean it thoroughly, and then LIGHTLY oil it with the recommended filter oil.
Enjoy your new quad
John
Old Mar 2, 2001 | 12:59 AM
partech's Avatar
I have a 98 3004x4 only one word 4 u Bullitproof!
I ride alot the only thing I have had a problem with is the cdi box cooked.The best advice I have 4 u is regular service & maintance.
Happy Trails
Old Feb 19, 2003 | 06:27 PM
97fourtrax300's Avatar
Default just bought 97 honda 300 4x4,possible mech problems?
I am also the owner of a '97 300 4x4. Everyone hit the nail on the head with the bullet proof thing. They are one heck of a reliable quad. Good luck with it.
neilbedwell
Nov 10, 2018 11:02 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
lovinhonda
Jan 25, 2000 09:17 PM
