'05 Big Bear Oil Filter Direction ???
Old Apr 3, 2010 | 07:16 PM
IBEW1's Avatar
Default '05 Big Bear Oil Filter Direction ???
So I got lazy and didn't remove my floorboard to do an oil change and the filter dropped out while wrestling it out. It's been a little while since the last oil change (no time to ride much last season) and I want to be sure before I put it back together.
Hole in filter toward engine, correct???
Now to cut that floorboard and weld a longer bracket, should have done it long ago.
Thanks, Bob
Old Apr 3, 2010 | 07:18 PM
IBEW1's Avatar
Guess I should have mentioned 400 Big Bear YFM40F
Old Apr 5, 2010 | 09:43 AM
DODGE57HEMI's Avatar
Mopar Man!
The hole on the filter should be facing the filter cover.
Old Apr 5, 2010 | 02:50 PM
IBEW1's Avatar
Pulled my floorboard off so I could get a good look in there and It's definitely "HOLE TOWARD ENGINE". There's a small fin that recesses into the filter, if it's turned the wrong direction that fin would push the filter out toward the cover preventing it from seating or crushing the filter if forced.
I had to ask though, once you get it in your head something might be wrong it's hard to proceed til you know for sure. Like they say, the only stupid question is the one you didn't ask before making a mistake.
Thanks Again!
Old Apr 5, 2010 | 03:34 PM
Mopar Man!
That is odd most of the older motor like that have the hole that goes towards the cap forcing the fluid towards the head. But if you made it work that is all that matters! Glad you got it running!
Old Apr 5, 2010 | 03:35 PM
IBEW1's Avatar
Thanks Dodge!
lightninboy
May 16, 2021 09:52 PM
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 19, 2015 10:13 AM
