clutch disassembly
Old Apr 7, 2010 | 06:07 AM
h03softail's Avatar
Question clutch disassembly
can anyone tell me how to pull the primary clutch apart once I have it off? thank you.
Old Apr 7, 2010 | 10:25 AM
EPIChad's Avatar
EPI has a video of a primary clutch disassembly on the website www.epiperformance.com and go the section called playground.
Otherwise it depends on how far you want to go. If you are just changing the spring and weights its not to bad. While compressing the clutch remove the six bolts on the cover plate. Mark the plate and the clutch before you take it apart so you put it back together the same way for balance. Slowly let the clutch come up and remove the clutch cover. You should be able to remove the spring and then there is no tension on the weights so they can be removed if needed. Do the opposite to reassemble.
Hope it helps
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
