50cc kazuma merkat
Good spark. sprayed starter fluid in carb nothing.took sparkplug out sprayed some in there put new spark plug in still nothing.compression seems good to me. I bought this used so I don't know history of it. Ran fine one day very next day went out to start it and it wouldn't start. Any help and all help would be appreciated
i didnt measure the spark. took spark plug out and then turned the motor over and can see the spark is there a measureing tool i can buy for this.
compression i just stuck my finger in the hole and it seems to be strong to me but i do have a compression gage i can check that
Im guessing the valves need adjusted.....
I have a Womat (newer version of the Meerkat) and oddly Ive had to put a valve in it already......after only about 2 hours of riding. Since then its been fine.....but that sucker was bent like a cheap penny.
watched you tube video on adjusting valves. ive never done it.looks fairly easy any hints before i tackle this.
my compression wont go as small as that spark plug hole.went to three different places today to get adapter with no luck. so i figured tommorrow id just try the valves and see what that does.
Welcome to the forum mpdp72!
I always adjust valves on a stone cold engine...(1 that hasnt been run in a few hours or more).. You want to adjust the valves at TDC.. A 4 stroke has 2 TDC's... you want the TDC just after the intake valves close..
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
