Suggestions please
Old Apr 19, 2010 | 08:03 PM
Ding Nut's Avatar
Default Suggestions please
I have a 2003 Trail boss 330.....I am waiting on my clutch puller to arrive to get into the gear case thought I might get some input from ya'll......my problem is:
Reverse....Locks in fine...all the power in the world.....but Forward...Grinds like a DEAMON, no power, I can hold the bike in place. Let the Bike go and it will move, but any added throttle and the grinding returns. Back off the throttle and the grinding stops.
any thoughts on what I should look for when I crack the gear case open?
Thanks
Old Apr 19, 2010 | 08:24 PM
Ding Nut's Avatar
Could it be as simple as a Sproket????? read somewhere that a guy has to replace his every so often.
Old Apr 20, 2010 | 04:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have you tried to adjust the linkage?? it might just be out of adjustment where you can hold it in and not have it grind.
Old Apr 20, 2010 | 08:46 AM
Ding Nut's Avatar
Yeah I monkeyed with the linkage....made it longer and shorter. But no difference. That is what leads me to believe it is something in the gear case.
Old Apr 20, 2010 | 08:52 AM
scootergptx's Avatar
Supersock
Hired Gun!
I had reverse go out in mine and was something as simple as a circlip. But it didn't have any grinding noise.
Honestly sounds like it could be more than just a simple fix.
Have you drained the tranny fluid to see if there's any metal in it?
Old Apr 20, 2010 | 10:13 AM
MECHANIKE's Avatar
mine is almost out,another day,not alot of time,probably an engagement dog gear,maybe also the large output gear, its easy, just need good snapring plyers,,,,,,,,,,i hope $200 or less,,,,,,,,,,,,,,,,,,,
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
badgerboy1
Sep 26, 2017 06:11 PM
Gwolf228
Feb 18, 2017 01:36 AM
Sw00p
Sep 24, 2015 02:50 PM
toonces
Sep 5, 2015 01:14 PM
