Magnum 325 reverse problem
Old Apr 20, 2010 | 06:40 AM
horzman's Avatar
Default Magnum 325 reverse problem
Hi, I have a Magnum 325 2x4..... it drives fine, but when I put it in reverse it doesn't sound right, as if it's caughing but faster. I don't usually use reverse so I dont' know how long it been doing it.
what could be the problem?
Thank you.
Old Apr 20, 2010 | 06:43 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Are you engaging the reverse over ride when it does this?
Old Apr 20, 2010 | 06:48 AM
horzman's Avatar
I don't understand your question.
as I am riding there are some areas that creek is so deep, so I put it in reverse to back up.
Old Apr 20, 2010 | 06:59 AM
horzman's Avatar
now I understand, I didn't know it has a reverse override... I will check later this evening.
Thank you
Old Apr 20, 2010 | 07:25 AM
Mr. Fancy Pants's Avatar
Thank you
mine have a yellow button on the bars (left side under the headlight switch) that say reverse override. It's a limiter so you can't go real fast in reverse (unless you want to).
Old Apr 20, 2010 | 07:50 AM
As far back as I can remember polaris has had a reverse override button.If you want full power in reverse, you must hold the button while backing up. It's one of those annoying saftey features that was probably a smart idea. If you want, check out the sticky for reverse override. You can eliminate it and never have to mess with override button again. very simple fix.
Old Apr 20, 2010 | 12:05 PM
horzman's Avatar
That was it... I cannot believe I never paid any attention to the over ride.
Thank you all.
Reactant
Mar 30, 2022 02:08 AM
steveo612
Jul 11, 2015 08:35 AM
Scottma518
Jul 10, 2015 12:42 AM
jettman
Jul 6, 2015 12:16 PM
bikedad3
Jul 2, 2015 02:15 AM
