Serviced the 850
Old Apr 21, 2010 | 11:14 AM
Kerbbirds's Avatar
Default Serviced the 850
I serviced the 850 this weekend, changed the engine oil and checked everything else,even though Po9laris shows a different part # for the oil filter it is the same as the 500, Wix # 51358, took the old one off, drained it and compared them side by side, the wix filter is exzactly the same.
Old Apr 21, 2010 | 11:57 AM
TLC's Avatar
TLC
The 850 can use a 500 filter?
Old Apr 21, 2010 | 01:07 PM
Chad1903's Avatar
What oil did you use?
I recently changed the oil in my 850 for the first time. Decided to go with the Polaris kit that has there oil I think its a 0W or 2W. To me it looked thicker than the 5w-20 that I use in my car. Was just wondering what you decided to put into your machine.
Old Apr 21, 2010 | 02:02 PM
bentarrow's Avatar
First Things First!
I called a dealer yesterday to check on parts for the recalls and ask how much $$ for fluid change on our 850. I think he must have misunderstood what I wanted, quoted $400 for all oil and lube but never called back if they had parts for recall or an appointment date. I think almost everyone must do their own service with those prices, I use Mobil 1 for the motor but everything else is Polaris.
Old Apr 21, 2010 | 06:40 PM
09 AR Sportsman's Avatar
ha-ha, yeah my dealer quoted me the same thing. I was going to do it myself, but i was just curious what they would charge. It was right at $400. i wonder if they get a lot of business....
Old Apr 22, 2010 | 07:42 AM
Kerbbirds's Avatar
i use castrol 5w 30 synthetic
Old Apr 22, 2010 | 10:36 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I too use Mobil 1 and Wix filters. The dealers have lost their mind charging those kind of rates for a one hour job.
Old Apr 22, 2010 | 02:10 PM
Chad1903's Avatar
Weedy, or anyone else;
Where are you picking up your Mobil 1 and what weight is it?
Old Apr 22, 2010 | 07:17 PM
bentarrow's Avatar
First Things First!
I use both 0/40 and 5/30 Mobil 1, from Walmart and Costco. Prefer 0/40 but had a coupon for Costco made a case of 6 quarts for $23 but they only had 5/30.
Old Apr 23, 2010 | 08:31 PM
HighVelocity's Avatar
The owner's manual calls for 2W/50 synthetic, which I've found is only available from Polaris. I'm using Mobil 1 5W/50 synthetic that I purchase from the local Esso bulk station. I also use the same Wix oil filter on both my '10 850 and my '03 SP500.
