regulator question
Old Apr 24, 2010 | 05:49 PM
soxfan68's Avatar
Default regulator question
the magnets came off the flywheel on my 1998 sportsman 500. It also took out the stator. I can't find a used flywheel anywhere. My neighbor has a 1996 Sportsman 500 he is parting out. The flywheel and stator will fit my quad but the stator has one extra wire. It's yellow with brown and looks like it goes to the regulator. The 1996 regulator is gone from the donor. What is the yellow and brown wire for and can I put a 1996 regulator on and make it work? I know it's kind of a goofy question but it looks like the cheapest way to get the Sportsman running again. Thanks
Old Apr 24, 2010 | 07:50 PM
The yellow/brown wire does go to the regulator. The colors on the regulator should be red,yellow,yellow/brown, yellow /red,and brown. Should be able to use the 96 regulator I believe. Just match up all the connections and the last one even if its not a yellow/brown should tie in. Be sure to check charging afterwards,around 14-14.5 volts. OPT
Old Apr 25, 2010 | 10:06 AM
soxfan68's Avatar
Thank you sooo much for your help. Now I just gotta get a regulator.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
