1995 300 carb
Old Apr 26, 2010 | 06:45 PM
fenderbot's Avatar
Default 1995 300 carb
Would anyone know why my carb would leak gas from the main jet soon as i turn on the gas from the tank i put a new needle and seat in and cleaned it several times the floats are good. i just dont have a clue what it could be any help would be great .Thankyou
Old Apr 27, 2010 | 07:11 AM
Kerbbirds's Avatar
Float level set too high, with carb on a level surface, and upside down bend tang on float so that it is level with the bottom of carb,could even be slightly less.
Old Apr 29, 2010 | 08:19 PM
fenderbot's Avatar
nope the floats are set right and i just put new ones in still it leaks could it be the jet? thankyou
Old Apr 30, 2010 | 04:27 PM
Kerbbirds's Avatar
Piece of dirt or something under needle and seat?
Old Apr 30, 2010 | 07:52 PM
MECHANIKE's Avatar
make sure your floats are Empty,,,,,,,,,,,,,
Old May 1, 2010 | 10:30 PM
fenderbot's Avatar
i shooked the floats they seem empty they are two little hockey pucks but i think that must be the problem cause it should work new needle seat the arm is set level to the carb. any other ideas?
Old May 7, 2010 | 06:28 PM
fenderbot's Avatar
well i put new floats in and still leaks but i found that if i unplug one of the three vacume lines it would stop leaking anyone know what the vacume lines are for? can i drive with it disconected any info. would be great thankyou
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
