850 xp skid plates
Old Apr 26, 2010 | 07:09 PM
850 trailrider's Avatar
Default 850 xp skid plates
anyone have any tips or advice on putting ricochet skids on their rides Im putting plates on mine and wondering if anybody has had issues or problems with installs that might save some time? thanks
Old Apr 26, 2010 | 07:44 PM
Miaugi's Avatar
I'd be interested as well, I have a full set of 8 pcs. to install and will be doing it sometime soon too. Tips and words of wisdom appreciated!
Old Apr 26, 2010 | 07:51 PM
hallj86's Avatar
They will collect mud. Thats the reason I dont have them the clean up is longer with them.
Old Apr 27, 2010 | 01:12 AM
Fishy MN's Avatar
The Ricochets are a pretty straight forward install. Rememeber that the smaller hardware uses 2 different sizes of metric hex-head bit on the a-arms. The rest of the machine uses a T-40 torx bit. If you have the bits available on a ratchet it makes things easier, don't overtighten.
If you can stand up the machine on it's rear it will make install much easier, we winched mine up to a steel I-beam support. Make sure you secure the machine.
It will definetly take a bit more to clean the machine but the added protection is worth it. If you have an Atv-Guru Brushguard you will have to slightly bend the front bash plate to fit.
Old Apr 27, 2010 | 07:28 PM
Miaugi's Avatar
Thanks for the heads up on the front bash plate as I do have the Guru's as well.
lonerider856
Oct 13, 2023 03:45 PM
Alex G.
Sep 11, 2017 11:38 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
