06 Sp 450 solenoid problem?
Old Apr 29, 2010 | 05:19 PM
Cutty's Avatar
Default 06 Sp 450 solenoid problem?
Please help me confirm my diagnosis. No start, no click, no nothing with the key. Starts right up with pull start. Checked key switch, have power to the white wire that goes to the solenoid when I turn the key, also have 12 volts at the solenoid end of that wire. When I jump the two large terminals on the solenoid the starter spins but the bendix doesn't engage. Don't you need to involve one of the two smaller wires for the bendix to kick in? What is the proper way to test the solenoid? Battery is fully charged and ok. Thanks
Old Apr 29, 2010 | 06:52 PM
Cutty's Avatar
Went back out there and played with it some more and now when I jumped the two big terminals it did actually start. Not sure why it just spun the starter without engaging before. Also have voltage at the other small (upper) terminal while turning the key. I'm assuming that the lack of any clicking from the solenoid indicates failure?
Thanks
Old Apr 29, 2010 | 11:26 PM
TLC's Avatar
TLC
The starter spin causes the bendix drive in the recoil cover to engage.
Old Apr 30, 2010 | 04:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you can start it by jumping the 2 cables on the solenoid you know the starter is fine.
Old Apr 30, 2010 | 07:43 AM
Cutty's Avatar
so is it safe to assume it's the solenoid? Don't want to buy something I don't need.
Old Apr 30, 2010 | 08:01 AM
TLC's Avatar
TLC
Sounds like a compound problem, if the starter spins but the motor does not turn over,that can only be a bad bendix drive.
Old Apr 30, 2010 | 08:35 AM
Cutty's Avatar
If you read my second post you will see that my bendix is working fine, not sure why it wasn't the first time but it is now. I just have no click or anything at the solenoid. I do have power from the key switch to the solenoid. Thanks
Old Apr 30, 2010 | 08:52 AM
TLC's Avatar
TLC
That bothers me also,if it was yours solenoid you think it would make a click ( But maybe Not). Have a friend hold a volt meter on the solenoid connection,when you hit the start button you should see a jump .
It does sound like the solenoid is you best bet though.
Good luck.
Old Apr 30, 2010 | 09:08 AM
TLC's Avatar
TLC
Here,s what the book says about testing the solenoid.
with key off.
Use a ohm meter set at RX1
Disconnect the small red/white wire from from solenoid.
Connect one meter lead to the small red wire attactched to solenoid,and the other lead to frame.
The resistants reading should be 3.4 ohms any higher means its shot.
Old Jun 4, 2010 | 04:29 PM
justinary's Avatar
ok well i just started the rewire on a ssr 250cc china quad well first no good so now im going to do this in questions 1 at a time ok i got my + from battery to syliniod then from syliniod to starter off the syliniod is 2 wires red/white and a black on can anyone tell me were these go so i can get this thing turning over.i got it with no good wire harness starting from scratch so please be gentle and ya alkl i want to run is what i need to nothing else lights sensors key nothin kill/run/start,starter,regulator,cdi thats all i want thanx again guys
