2003 Sportsman Speedometer warning?
Old May 3, 2010 | 12:44 PM
Farmeralan's Avatar
Default 2003 Sportsman Speedometer warning?
I have a 2003 Sportsman 500. On the digital screen area of the speedometer the little hour glass blinks on and the word "SEAEr" (Top arm of E missing) appears for about 5 seconds then looks normal for about 15 seconds then blinks on again. Does anyone know what this means? I can't find my manual, I have reset the service clock, and disconnected the battery for 1/2 hour, reconnected it and it still does it.
Old May 11, 2010 | 07:58 AM
Farmeralan's Avatar
Could the word be "Statr" (STATOR)? my 14 year old daughter rode it and thats what she read it as. I replaced the battery as I knew it was weak and tested the charging system and at idle it charges right at 13 volts, and it still does it. Has anyone had their stator go out and have a code like this show up on the speedo?
Old May 11, 2010 | 05:33 PM
Kerbbirds's Avatar
The 2003-2004 speedo did not say anything about stator, it did have an ERROR warning, does it properly show which gear its in? P_N_H_L_R if not, the switch on the tranny is bad and causing the ERROR on the speedo
Old May 11, 2010 | 09:17 PM
Farmeralan's Avatar
It does have gear indicator on the left side, a big H, L, N, & R the 03 doesn't have park, I'll have to check tranny switch. Thanks for the reply
Old Oct 25, 2020 | 12:42 PM
Westva's Avatar
Default Having same message statr
did you find out what was causing your bike to have that message my 03 is doing the same thing .
Old Oct 25, 2020 | 12:54 PM
Westva's Avatar
Default 03 sportsman 500ho
the message center comes on ok then starts switching modes from reading off on screen with wrench and hour glass at top not blinking then to the wrench blinking and the word statr at the bottom of screen and the tac jumps up bouncing between 15 and 20 but not running any help would be great thanks
Old Aug 2, 2021 | 06:07 PM
Stuckinohio's Avatar
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
velcro7279
Aug 24, 2015 01:15 PM
sweaver
11
Aug 18, 2015 03:47 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
