09 850 XP wont start...
Old May 4, 2010 | 02:08 PM
09' Sportsman XP 850's Avatar
Default 09 850 XP wont start...
My XP wont start, the battery is fully charged and there are NO loose wires. After I washed my XP, I went to start it, it rolled twice then just started "clicking", is it possible my starter got wet?
Old May 4, 2010 | 03:10 PM
SCRAMBLER500XXX's Avatar
the starter relay probably got wet
Old May 5, 2010 | 12:01 PM
I tried to start my XP today, it rolled twice, then the starter just "clicked", does this mean the battery is dead? Because, according to the battery charger, its full...
Old May 5, 2010 | 12:25 PM
uncle matt's Avatar
I would only access the battery with any chargers disconnected and using a good voltage meter. If the voltage is good then I would monitor the voltage for drop when you try to start it. You should see a good drop of voltage. But if the voltage drops to very low volts you might have a bad battery.
Old May 5, 2010 | 12:55 PM
Speeddrive1's Avatar
Check the battery terminals to make sure that they are tight. It has been an issue with the loose connections on some 850's including mine.
Old May 5, 2010 | 03:11 PM
Connections are tight as can be...
Old May 5, 2010 | 06:28 PM
Yea I thought that too. What happens is the battery cable terminal catches the raised plastic on the battery. I had to put a small washer between the battery terminal and the cable as a shim to make some clearance.
Old May 5, 2010 | 08:46 PM
Tried that, I even hooked a truck battery up to my XP, and still the starter only "clicks"... I'm getting fed up!!!
Old May 5, 2010 | 08:57 PM
Miaugi's Avatar
I would try to "tap" on the starter with the wooden end of a hammer or a rubber mallet (may not be enough room for this option) as this was an old trick for similar problems on car starters many moons ago. Don't break anything, it's just to see if it will free something up and allow the starter to kick in.
Old May 7, 2010 | 11:43 AM
Figured it out, my starter is done, apparently they're not as waterproof as one might think...
The inside of the starter is rusted and coroded, and wont even spin. I suggest all 850 XP owners keep an eye on the rubber coating on the starter for rips and tears, as a new starter is about $500 or more...
tiresharkdbb
Sep 3, 2017 02:06 AM
brion519
Sep 7, 2012 12:42 PM
cstrait37
Feb 10, 2012 11:51 AM
keno-cheye
1) Engine problems..
14
Apr 26, 2010 11:03 PM
cableguy256
Apr 10, 2010 09:59 PM
