Did not expect this!!!
Old May 4, 2010 | 02:15 PM
sassee's Avatar
Default Did not expect this!!!
Last saturday as i was removing the covers to do a visual check on my shifting problem, i drained the crankcase first only to find it full of gasoline! Now I know how/why it's there but can the gas in the oil cause the shift problem I'm having? I guess I can bolt the covers back on and fill it up with clean oil and find out!
Old May 4, 2010 | 03:33 PM
cupsz71's Avatar
Cool
Sounds like your float is stuck. Gas is flowing into the crankcase when the machine is sitting. Adding new oil is a short-term solution - VERY SHORT. You'll most likely need to pull your carb and clean it if you don't have a fuel shut-off. (yr?)
I'm not fully up-to-speed on your shifting problem. (manual/auto?) What's it doing?
Old May 4, 2010 | 06:15 PM
sassee's Avatar
I have gone thru the carb and taken care of that issue. Actually, my question is could the gas in the oil cause my shift problem that I posted the other day? The atv will not shift. sometimes I get it into second but that takes some banging on the shifter. once it's i gear, it runs fine! I pulled the covers off but found no broken parts to tell me whats going on. If the gas in the oil did not cause this then I guess I have to keep dissecting until I find the problem
Old May 5, 2010 | 06:22 AM
Moike's Avatar
It is not likely going to cause the shifting problem. It might make it a little more difficult to shift.
After you repair the fuel in oil problem you will need to investigatte further to find the root cause of the shifting problem.
Customer Service #1
May 15, 2020 08:46 AM
mtdewmn
Jan 19, 2017 12:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jason Poulin
Sep 20, 2015 02:49 AM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
