Polaris 300 Xpress hard to pull start
Old May 5, 2010 | 10:51 AM
loquist's Avatar
Default Polaris 300 Xpress hard to pull start
I've been working on a 1998 Polaris Xpress 300 that didn't have spark. After taking care of the spark issue I tried to pull start it. After a couple of minutes of trying to start it, the engine suddenly became difficult to pull past TDC. I took the spark plug out and it pulls with ease, but it is extremely difficult to pull past compression with the plug in.
What could have suddenly plugged up that would cause this to happen?
Thanks in advance for any advice you may have.
Loquist
Old May 7, 2010 | 01:16 PM
loquist's Avatar
Any takers?
Old May 7, 2010 | 02:20 PM
MECHANIKE's Avatar
will it turn by starter??
Old May 7, 2010 | 08:57 PM
loquist's Avatar
Thanks for the reply.
It will turn over with the starter, but it has a hard time, just like the pull start.
Old May 8, 2010 | 05:32 PM
MECHANIKE's Avatar
maybe it has a compression release that is bad, if it has one, ever check compression? if its free when you pull the plug and no scrapping noise like a broken ring,or even your stater drive locked into your flywheel,,,,,,,,,,,that would make both hard,,,,,,,,,,
Old May 9, 2010 | 06:29 PM
ofie's Avatar
same issue with a 1999 Polaris Magnum 500, starts fine with starter but almost impossible to pull start.
Any ideas????
Old May 9, 2010 | 07:27 PM
MECHANIKE's Avatar
if your talkin about HOT its normal that i've experianced, cold no prob, hot,build up of compression,about rip me hand off,,,,,,,,,,,,,
Old May 9, 2010 | 07:58 PM
ofie's Avatar
no, cold starting, first start of the day.
Old May 9, 2010 | 08:12 PM
Mongrol's Avatar
"Official Site Skeptic"
I'll go for the compression release being faulty.
Old May 9, 2010 | 08:55 PM
MECHANIKE's Avatar
10/4 Mongrol
