CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
need help
Old May 12, 2010 | 10:31 PM
lanerholloway's Avatar
Default need help
Having problem with my ds 650 when in fifth gear at top speed my bike will drop about a 1000 rpm all the sudden and if I dont let off the gas it will die. could the problem be the cdi boxs? I have Big Gun rev box on it.
Old May 13, 2010 | 07:20 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
It sounds like a fuel problem. Check vents ,fuel peck (flow to carb bowl) and needle and seat in the carb, In that order.
Old May 13, 2010 | 10:01 AM
justme23005's Avatar
mine did that, when the float level was too low
Old May 13, 2010 | 11:57 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
If you have a tach, note if you are hitting the rev limiter - 8700-8900rpm
Old May 13, 2010 | 12:22 PM
In gears 1-4 my tach will go up to 8300 but in fifth gear it goes up to about 6500 and the it will drop.
Old May 13, 2010 | 02:20 PM
OMR's Avatar
OMR
When you pulled a plug, what was its color.
If wet and dark, pull out the other plug also.
One step at a time.
OMR
Old May 13, 2010 | 02:26 PM
I have a inline fuel fillter on it could that be the problem
Old May 13, 2010 | 06:21 PM
OMR's Avatar
OMR
Bingo.
I would disconnect the filter and retests.
I tried a inline filter once and it went dry for me also.
I think the DS is too large a motor for these small filters.
Check one plug also.
OMR
Old May 13, 2010 | 07:21 PM
Ok i will try it without the fuel filter on it. could the problem be the cdi box??
Old May 13, 2010 | 08:29 PM
OMR's Avatar
OMR
I have had cdi go bad, but not intermittant.
Cdi's either work or fail.
On cars the coils will sometimes fail at a high rpm under load.
