Dead KAW 300 Prairie
Old May 16, 2010 | 09:49 AM
Sundance1's Avatar
Question Dead KAW 300 Prairie
Have a 2001 Kaw Prairie 300 4WD. Pulled into garage - shut off. No power/no starter function. No green neutral light. Fuses seem OK. Battery OK, runs when pull started and when running green light glows faintly. Key switch and kill switch both shut down engine.
Old May 18, 2010 | 01:42 PM
bustedknuckles's Avatar
I would start at the battery and check all of your ground conections clean and tight a little corrosion goes a long way in causing electrical problems.
Old Oct 25, 2010 | 08:01 PM
lance0403's Avatar
make sure the both fuse are good right next to battery. bad fuse will cause that there are two fuses there a 30amp and a 3 amp
pgamboa
Dec 24, 2023 11:52 AM
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
DM2015
Sep 7, 2015 10:36 AM
