Stumbles at 3500rpm with TM45 on it
Old May 18, 2010 | 09:22 AM
lilnotts's Avatar
Default Stumbles at 3500rpm with TM45 on it
I cleaned my carb and after I reinstalled it it runs great at idle and above until I hit approx. 3500rpm. If I punch the throttle it will stumble then rev out with no problem and will run fine again until I lower the below 4000 and then it begins to stumble again. I'm wondering if I bumped the adjustment on the accelerator pump, would that make sense?
Old May 18, 2010 | 11:05 AM
NickDS650's Avatar
When i had the TM45 i had problems with my intake boot collapsing, they fixed that with the newer model DS's with ribbed boots, but checking that is a start
Old May 18, 2010 | 04:09 PM
lilnotts's Avatar
the weird thing is the machine ran fine before I took it apart
Old May 19, 2010 | 12:11 AM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
Smile
I would recheck the accelerator pump maybe needs adjustment
I had the same problem, a perfectly good ds untill i started working on it
Old May 29, 2010 | 11:30 AM
lilnotts's Avatar
I've found that there are some cracks on the intake boot between the carb and the airbox and also the o-ring on the accelerator pump nozzle was not holding the nozzle very well letting it turn under vibration and wow are those o-rings hard to find
Old May 29, 2010 | 03:40 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Ron Wood Racing should have everything yoou need for the TM. I say should!
Jmuddin284
Jan 19, 2026 07:16 AM
neilbedwell
Nov 10, 2018 11:02 AM
Jul 30, 2015 09:39 AM
Hightower
Feb 12, 2003 11:08 AM
JIGA
Oct 30, 2000 01:28 PM
