05 650 V2 LE Pops out of High Gear Runs Sluggish
Old May 24, 2010 | 03:10 PM
arsonfnder's Avatar
Question 05 650 V2 LE Pops out of High Gear Runs Sluggish
Any suggestions on either problem, have a 2005 V2 650 that runs ok although it backfires and only will go 26 mph??
Will pop out of High Gear, could this be an adjustment issue?
Old May 24, 2010 | 03:49 PM
weez440's Avatar
sounds like it is in limp mode. i don't know about the 05's but the 04's the belt light comes on in the instrument cluster. you can either reset it due to a power spike or else there is a switch inside your clutch cover that you can turn off if it was tripped by the belt. if you hit 100 hours on your machine i know the 04's would also go into limp mode at 100 hours. as far as it popping out of high range i would put it all the way up into low range and loosen the two adjust ment bolt in the linkage and it should automatically slide where it is supposed to be.
txkevin
Sep 21, 2015 02:02 PM
Jun 10, 2015 11:20 PM
Big600twin
Jun 10, 2015 03:01 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
cornermike
May 27, 2015 10:04 PM
