prarie 360 4x4 stalls
Old May 31, 2010 | 06:23 PM
ataxia162's Avatar
Default prarie 360 4x4 stalls
I have an 06 360 4x4 I bought new. It ran fine till I took it to the dealer for maintenance after a few hours. After that it tends to stall when I let off the gas. I had the valves adjusted and it ran good again. Now it has gotten worse than ever. It will only idle if the choke is partially on, stalls every time I let off the gas, is hard to start, runs rough and backfires.
I can't do the maintenance myself, had the valve clearance checked, replaced the plug. No one seems to be able to find the problem. Has anyone had this problem? and what can I do about it?
TIA
Old Mar 18, 2011 | 09:24 AM
Hayashi's Avatar
Check/measure valve clearance again and let me know what they are.
Old Mar 19, 2011 | 01:57 AM
ataxia162's Avatar
Default Problem Resolved
Sorry for not doing this sooner, I forgot about the post.
Turns out the problem was a crack in the carb holder. Was under the clamp so you couldn't see it without removing it.
I appreciate the responses
Old Mar 21, 2011 | 09:31 AM
Hayashi's Avatar
Is that the black rubber boot that holds the carb to the cylinder head?
Old Mar 21, 2011 | 06:02 PM
ataxia162's Avatar
Yes, that is the part. Couldn't see it till you took it apart because it was under the clamp.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
